DC 3535 error 004-341
  • mayur
    i am getting error on my DC 3535...
    the error code is 004-341...
    plz some one help me with this error and give me solution...
    thanks
  • johnner66
    • Mar 2009
    • 265
    try to look at the connected mcu pwb p/j 401-b20 that connected to the laser unit make such is proper connected if no try replace the laser unit this can be cause by the interlock relay pwb also so goo luck
    • jayc67
      Independent technician
      • Sep 2009
      • 100
      Check already that the 4 drum cartridge and the waste toner bottle are correctly installed
      • davidj7
        • 1107
        check drums
        a machine is only as good as your tech : source:screwtape ; the scary one
        • TechMate
          • Mar 2008
          • 285
          It could just be a corrupt NVM on the machine which means you need to reset the NVM values to factory settings. Also have the machine's firmware level up to date.
          Also, you need a software patch on your bustled RIP from Library 4122 on the Xerox GSN network. In Other words, update the system software of your bustled RIP. THanks
          • Peter Montgomery
            • 52
            Xerox DC 3535 error code 004-341
            The Xerox DC 3535 error code 004-341 can sometimes be fixed by adjusting the fuser standby setting NVM (744-077) from 130 to 160 (Default)
            Or Maybe the IBT Belt is not tracking properly, Rotate the belt back to the centre of the IBT assembly then, If you have Diag do a belt edge learn adjustment. if not just centre the belt then reboot the machine.
            Hope this helps.
            Colour Copier Service http://www.colourcopierservice.com
            Connect with me on...
            Facebook http://www.facebook.com/video/video.php?v=1223670679806
            Twitter http://twitter.com/pete_montgomery
            YouTube http://www.youtube.com/watch?v=_oc2wp_6T6k
            Blog http://colourcopierservice.wordpress.com
