PWS won't connect
  • Bluezman
    • Mar 2009
    • 33
    PWS won't connect
    I can get pws to connect to the M24 any ideas??
    D
  • davidj7
    • 1107
    are you trying to connect via USB to serial or serial cable
    a machine is only as good as your tech : source:screwtape ; the scary one
    • Bluezman
      • Mar 2009
      • 33
      USB to Serial
      • suckis
        • Dec 2006
        • 165
        Are you sure you are trying to connect via COM1?
        ! RTFM !
        My site: http://www.e-club.gr/
        • davidj7
          • 1107
          check the com port number of your usb to serial cable and match it to the com port of pws
          • Milo Wilson
            • 502
            It should definitely be set to com1
            • XeroxTechBrazil
              • Aug 2008
              • 199
              Check Version of Diagnostic Tool
              Check the version of your diagnostic tool if forcing the USB> serial converter to Com 1 doesn't do it. Latest for EPC is 3.10
              • copytech200X
                • 264
                usb to serial must connect to com 1 .
