doc 242 adj 9.13
  • lakeman78701
    • May 2008
    • 44
    doc 242 adj 9.13
    does any one have the adj 9.13, " belt edge learn cycle" , that is not on the pws, I just dont have the pws right now. I just need the adjustment rap so I can be sure and get the belt I am installing set up properly. thanks again to all. a quick nvm number or location that I can input to do the adjustment would be great. you can email it to me at:
    lakeman78750@yahoo.com
  • kalindd
    • Jun 2008
    • 192
    1. DocuColor 242/252/260, select Sub System, Belt Edge Learn.
    2. Select Start on the screen.
    With DC242 this can be run ONLY from the UI , you can't do it from PWS.
    Also before running Belt edge reset NVM location 741-105 to 0.
