Xerox 8860
  • snook123
    • Jul 2025
    Xerox 8860
  • CopierTechofOmens
    Agitating Artificer
    • 268
    That could be a couple things. Poor oil chase from the maintenance kit caused by broken cams. The Drum could be heating improperly. Also, the transfer assembly could be binding up on one side.
    sigpic
    • csudca
      Does this device produce a lot of waste toner?
      • landspeeder
        • Feb 2010
        • 355
        only when it runs out of ink!
        also I would go with the broken DM cam!
        You never realize how cheap a professional is until after you let an amateur do it.... and
        if this was an easy thing to do then everybody would be doing it! But it isn't and they are not!!
        • JustManuals
          • Jan 2006
          • 9838
          You DO realize you're responding to a post originally made in Nov. 2009 right?
          • landspeeder
            • Feb 2010
            • 355
            no...I didnt read that area....but it could be a broken DM cam and he may be still waiting for a reply...sorry
            • JustManuals
              • Jan 2006
              • 9838
              No need to apologize, I was just pointing it out.
              Paul
              • landspeeder
                • Feb 2010
                • 355
                nothing better than manual4you they are the best!
