workcentre 238 scanner enablement
  • fenave69
    • Jul 2009
    • 16
    does anybody have a code to enable scanner features in a workcentre pro 238 ? thank you
  • tech9
    • 216
    you will need a pin number which you must enter in optional services in tools
    • fenave69
      • Jul 2009
      • 16
      pin number scanner
      don`t you have the pin number , the problem is that i had to change the hd and now i need it and the customer lost the book with the pin number
      • jeanpaul
        • Mar 2009
        • 117
        the code is 49825005
        • fenave69
          • Jul 2009
          • 16
          ok , thank you jean paul , anything you need in the future i hope i can help you , by the way don't you have a code for workcentre pro 45 ? thanks again
          • lgnis
            • Sep 2019
            • 6
            Re: workcentre 238 scanner enablement
            Hello, the code for enabling scan to file in
            Xerox WorkCentre Pro 245
            is: 77054783
            Regards!!
            • fenave69
              • Jul 2009
              • 16
              is: 77054783
              Regards!!
              OK, thank you
