Xerox CC 245 pass code
  • bojans
    • 1313
    Hi,
    Does anyone know password for changing billing scheme on this machine?
    I have to change SERVICE PLAN to Plan B.
  • TzALbg
    • Dec 2007
    • 111
    Why do you want to change service plan.
    It is normal B plan
    • bojans
      • 1313
      It is normal B plan
      Hi TzALbg,
      My companion was on the field, and after changing Xerographic module he got message "incompatible Xerographic module, please change". Right now i don't know the part number of this module. He has changed CRUM chip from damaged Xero module, but there is only 40k left. I've found in Eureka that i have to change Service plan???? maybe to A??? I don't know which option is now on machine, i suppose i have to change it...
      Best regards
      • TzALbg
        • Dec 2007
        • 111
        I will check all mashine which service plan have
        but I check two and they are service plan B
        • xcopytech
          • Aug 2006
          • 1794
          first check drum pn.
          • bojans
            • 1313
            OK thanks
            Hvala
            • bojans
              • 1313
              PN 113R672
              There were 2 machines on the site. One works fine, the other says i don't like this drum
              I'm about to go on the site next week, so i'll keep you informed on this problem.
              By
              • xcopytech
                • Aug 2006
                • 1794
                113r00608 = wc 232-238
                113r00672 = wc 245-275
                • adriansto
                  • 2387
                  Originally posted by bojans
                  Hi,
                  There is 2 types of XCRU:
                  113r672 is ' metered' type and it keep the SERVICE PLAN default to B
                  113r673, 113r674 is 'sold' type and it will set the SERVICE PLAN to A when you put it in to machine. From that point on the machine will no longer accept ' metered' type.
                  Tou may use MRD (critical floppy) that came with machine to restore the factory settings.
                  Oh I think you need PWS to restore from MRD ....
                  • bojans
                    • 1313
                    Thanks adriansto for making things clear. Customer inserted 673 or 674 and changed service plan to A. So i was right when asking how to change to B. I have PWS but they don't have MRD, that's why i was asking for code...
                    by
                    • adriansto
                      • 2387
                      Make a MRD from second machine on the site and try to restore from that.
                      ONLY IF THE SAME SOFTWARE LEVELS !
                      • bojans
                        • 1313
                        I just realized that I didn't reply to this post.
                        Thanks adriansto, problem was solved by reloading MRD.
                        I also got program which generates codes for changing wrong service plan.
                        If anyone needs it , send PM.
