i have a 3535 and am trying to print duplex on SRA3 via the bypass tray. I print the document on the one side and then manually turn the page over and print the same document on the other side but it is not aligned properly. Its almost as if its printing for a book where the image is printed more to the left? I have tried enableing "Align tray" but doesnt make a difference. How do i acheive this?
Duplex printing
A workaround could be to make sure the paper goes through the printer with the same leading edge for both sides, you would then have to rotate one side 180 degrees. That way the print may not be centered on the SRA3 but it's more likely to be registering front/back.Comment
A PWS is the computer that a technician uses to connect to your printer/copier, I'm sure DavidJ can explain why you may need to use one in your situation.Comment
with pws you can adjust the margins by changing the NVM settings . since you dont have pws i suggest you call a tech and ask him to fix the tray nvm settingsa machine is only as good as your tech : source:screwtape ; the scary oneComment
There's another workaround, since you are printing on SRA3 I'm assuming you have plenty of space on the sheet for your book cover. So, if the front to back misregistration is the same, you can simply move the artwork on one side accordingly, I do that all the time.Comment
