DC12 with EX12 fiery: how to Change Language?
  • dorje
    • Jun 2025
    Dearest friends:
    I have a DCCS50 with cobra and I decide to change the rip with an EX12. I bought one from a warehouse in Germany. It is in perfect condition outside and works fine. I plugged it on my DCCS50 and worked immediately. The only problem I have is that the LCD Control Panel of my EX12 is in German. Please, does anyone knows how I can change it in English? With the EX12 I received also the CD 3 of 3 with the documentation. Also, the Windows NT in the system is in German too but that does not mind me. The only change I like to do it to change the language of the LCD panel. The version of the software is Efi Fiery v. 2.0 SP2.
    Thanks for your help in advanced
    yours
    Evangelos Sykiotis
  • xcopytech
    • Aug 2006
    • 1792
    must install english system software on ex 12
    • dorje
      how to do?
      Thanks very much for your reply.
      It would be helpful for me to let me know how I can do this? How i install again the software? As I already mention the only I have it the fiery with the software installed and just the CD 3 of 3 (Fiery EX12/EX2000d User Documentation v2.0). I need to have the other CDs too or I can do it from the fiery hard drive? From the folder backup in C: of the fiery I run the Install.exe but it installed again the DC12 fiery in German. I try also and run setup.exe and setup.bat, but run in CMD and installed again the software in German. Alsto I found in the folder with setup.bat a file with Enlsish.bat, I run it too and when started to run after a while appeared a message about a brain.dll file to overwrite. When press YES then for several hours the procedure stoped there and nothing happened. I restart the fiery and run again the file and I choose NO, as I did with the other files later that asked to overwrite. In this was the setup completed but it was again in German. Nowhere found any option for Language.
      I would be pleased and Greatful if you let me know how to install in English.
      • gregoryk
        hi patriot.Etch fierry sold with its own softaware deppending the country.Probably yours does not include the english .Search the forum and try to make an exchange (german for english) or try to download it from xerox.com.Sorry for the english replay.
        • dzielnicowy
          Originally posted by hmelo
          Hi, You have to get the 2 CDs!
          1 of 3
          2 of 3 Inglish language
          The only one You go is the 3 of 3 ( its not crucial )
          I can send You the 2 Cds, no problem!
          email - helder.melo@netc.pt
          I need too system disc with the english language. I have german version of ex12. My mail: dzien.misia@hot.pl
