RE: X12 Fiery with Xerox DC12, DC1250 hangs at configuring hardware.
This is a visitor message I received and I thought it would be good to open it up to the whole forum.
Hi Krish,
"Quote from Krish to Peter".
hello sir i m using x12 fiery with dc12 when i start my x12 fiery it hang or halt at configuring hardware but by next day what isee that there is no display on front side of fiery i checked with other RAM too pls help me to resolve this issue.
Peter to Krish,
There are always many possibilities when you get these types of problems.
Do you have a service manual for this fiery?
Try these guys, I see them everywhere on here they might have the Fiery manuals.
Manuals 4 You - Copier-Printer-Fax Manuals etc
The Internet's largest collection of manuals
The simplest first step is to reseat "ALL" the boards and connections a few times inside the fiery to make sure the connections are good.
In other information I have it says this:
It could be a faulty mother board or a bad connection between the Bios Chip to the mother board via the spacer/socket.
In which case you could remove the spacer from U8 and install the Bios chip directly into the socket.
Try this and tell me how you go.
Hi Krish,
Peter to Krish,
