When is it time to change these Doc 250 parts?
  • Oktobernv
    • Mar 2009
    • 38
    I have a Doc 250.
    It currently has about 225,000 clicks on it.
    What is the "suggested" time frame on changing the following parts: ??
    #1 - 2nd BTR?
    #2 - Transfer Belt?
    #3 - Developer Housings?
    I run 100% COATED stock. Generally 12pt cardstock. 280 gsm
    Thanks in advance,
    Rob
  • Oktobernv
    • Mar 2009
    • 38
    Anyone have an opinion on this?
    • xcopytech
      • Aug 2006
      • 1793
      2nd btr 600-700K
      transfer belt 300-400K
      developer assy change when is damaged
      • pe6ohh
        • Nov 2009
        • 17
        Hi there !!! Happy Holidays to everybody !!!
        That what xcopytech said is depend on SM but I have machine on 550k and I have to change the transfer belt ( for example ) 3 or 4 times.That`s depend on your job.My costumers work with bad media 300gsm and more 100% full color copies.I change this parts mostly from copy quality problems.
        So what I want to say is : If You don`t need it do not change it
