DC12 cobra rip - network controller disabled
  • regalcopy
    • Oct 2007
    • 58
    Dear All
    DCCS50 Problem - Network Controller disabled
    this appears when a print is sent to printer.
    thanks
  • gregoryk
    HI! before ordering a lot of expensive parts try to reload dccs50 controller software
    • davidj7
      • 1107
      yeah! cobra uses a filthy software. its duty is to cause trouble and give wrong messages.
      I threw my cobra rip and took in a x12 a month after install
      • AjitN
        • Mar 2009
        • 287
        Please check if you are using correct printer driver. Cobra I is developed by Splash Technologies and Cobra II is from EFI. Printer drivers are not compatible to each other. If you are able to get one print and then cobra is going offline OR controller disabled, then it could be priver problem.
        Ajit
        • Goshe
          • Jul 2009
          • 118
          Check NVM location 752-008.For Copier/Printer should be 1 and for Copier/Printer/Scanner should be 2.
          There is also another NVM location you must set for Cobra,but I can't remember what it was.If I found it I'll post here
          • maxman87
            • 14
            i had cobra fiery with xerox dc12
            i need the controller firmware to refresh the controller
            my email id is manojsaini87@gmail.com
            thanks in advance
            • davidj7
              • 1107
              controler software or machine firmware
              • maxman87
                • 14
                both
                • davidj7
                  • 1107
                  have mailed you cobra installation files .
                  • maxman87
                    • 14
                    download required password
                    • Goshe
                      • Jul 2009
                      • 118
                      This is older post but I said that I'll post some NVM settings for dc12/dccs50
                      759-053 set to 1
                      752-008 set to 1
                      799-004 set to 0 for dccs50 and 1 for dc12
                      • Goshe
                        • Jul 2009
                        • 118
                        759-004 set to 0 for dccs50 and 1 for dc12
                        • WIWA
                          • Mar 2009
                          • 97
                          Uh! those cobras kick like a Cobra. Well first ther are to type first serial start with an M (software level 1.54 and 1.74)and have 5 leds on the side ,the second type start with G (software level 3.0 and 3.2)and have 6 leds on the side . Be carefull software CD are not interchangable you can kill the motherboard so verify you have the right software for the right serial our you may be in trouble. By the way have and oldy cd rom in hand most of the problem installing software are the cd rom readers dead or faulty is my experience just in case.
                          Hope this help.
                          Wiwa 72
                          Gonzos build v.1.0
