HELP on the Chip Resetter
  • Enzo
    • Jul 2009
    • 413
    Hi friends. I have need that someone told me whether to be able to acquire a good chip resetter for the xerox dc440. I camp your useful suggestions. thanks...
  • mp4wizzard
    • Nov 2009
    • 37
    This maybe helpful
    I've posted it as suitable for Xerox and Dell, but really any item (Cartridge or drum) that has a chip or reprogramable eeprom and be rechipped or reprogrammed.
    Firstly
    It's also handy to have a set of new / unused chips so that you can read the "full" data.
    I have the bin dumps for the Xerox 6130 and 6140, if these are useful
    I made this little device, (See links to pictures below) it will allow you to re-chip or re-program the eepron that is embedded in the PCB on most toner cartridges and drums.
    See this link for pictures.
    Picasa Web Albums - mp4wizzard - reader pictures
    This device also works for several other similar cartridges including DELL 1320
    It's also useful to know which pins are
    GND
    VCC
    SCL and
    SDA
    I'll try and help if anyone needs this info........... but no promises
    This is where you can buy the basic unit.......... I've put mit in a little box for protection
    USB 25xxx SPI Bus E-Eprom programmer - Microchip, ATMEL on eBay (end time 02-Feb-10 09:41:48 GMT)
    Before you ask, he's not a relative, but a very helpful chap.............. speaks very good English and he comes highly recommended.
    Ask him nicely and he will send spare connectors and USB leads...... free
    I had to make a recepticle to "plug" the chip into, not pretty as you can see from the pictures, but it works.
    You will also need a small piece of software to read and write the hex data
    The software can be found here............ it's been tested by me and is perfectly safe and easy to use.
    http://www.sigma-shop.com/software/k..._24xxx_03c.zip
    You may also need this drivers:
    Virtual COM Port Drivers
    Let me know if you need any more help / information
    Eddie
    • Enzo
      • Jul 2009
      • 413
      and do these objects work for resetting the chips of the xerox dc440? how much would it come me to cost the whole purchase?
      • mp4wizzard
        • Nov 2009
        • 37
        Honest answer............. I'm not sure if they will work as I do not have a dc440 or worked on one.
        Can you send me a picture of the chip that you would like to reset / reprogram?
        I should be able to tell you from a picture
        Eddie
        • Enzo
          • Jul 2009
          • 413
          • mp4wizzard
            • Nov 2009
            • 37
            I'm not sure mine will , but this will
            XEROX DC12 DCCS 50 DC 1250 Drum reset chip 013R00560 on eBay (end time 05-Feb-10 12:19:54 GMT)
            Good luck
            • mp4wizzard
              • Nov 2009
              • 37
              Sorry, just been told this will NOT work on the DC440 ............
              Eddie
              • Enzo
                • Jul 2009
                • 413
                ok thanks
