Hello everyone.
I had oil lines fused into my prints from my docucolor 12. I changed the oil metering blade (squigie) because I saw it was leaving oil streaks on the pick up roller. Now it seems that the metering blade removes to much oil because the cleaning web is covered with toner and the prints don't have enough oil. Tried another pick up roller still the same problem. don't know if it would be the donner roller, top fuser roller or the metering blade is just removing to much oil. Don't think there is an adjustment for that blade. I have a manual. Need HELP this is making me go crazy.
Thank You
John
Thank You
John
