xerox 8550dt
  • alexfixes
    • 68
    xerox 8550dt
    I have 8550 is making double prints. I run some test and it looks like it could be fuser unit. I have worked on konica machines and not that familiar with this one but the symptoms are same when making double prints or print head.
    I have repalced fusing unit on konica machine and fixed the problem. this double prints is mostly all the time. It only did print fine when i send to print but one time after that it keeps doing double prints.
    thanks for any help.
  • gregoryk
    hi. probably you mean xerox phaser 8550 .Your problem seems to be the cleaning unit (maintenance kit)
    • alexfixes
      • 68
      yes, xerox phase 8550
      does the kit includes the fusing rollers like big copiers?
      thanks any help to get this going. How much is the kit and what's involved...
      • Milo Wilson
        • 508
        No fusing unit per se. The kit is an oiler roller for the fixing unit and a cleaning blade. I think they run about 180.00
        • alexfixes
          • 68
          oil roller
          ok, thanks. sometimes on othr name brand we change the whole fixing unit. i call fusing unit the same. do you have the part# for claning blade and oiler roller.
          thnaks for your halp
          • alexfixes
            • 68
            I pulled out the kit which has roller and the blade, the claning blade looks bad. I cheked the on line it's like 148.00. this is easy to replace compare to replacing blades on big copier
