Phaser 8400 message 37,004.40:23845 error service required
  • smith60gs
    • 19
    hi can anyone shed some light on this error? thanks P
  • smith60gs
    • 19
    ok
    i managed to find service manual and have run the heater test i get the following reseult
    R0 234.0208
    R1 20.2667
    R2 3148.2019
    R3 -.3216
    R4 -16.000
    R5 20.2667
    R6 20.2667
    R7 .0000
    R8 20.2667
    any ideas?
    • landspeeder
      • Feb 2010
      • 355
      Common......have to change the printhead..crack in a board ....work around is to go to diag and turn the heaters on to get them real hot and then reboot..usually works
      You never realize how cheap a professional is until after you let an amateur do it.... and
      if this was an easy thing to do then everybody would be doing it! But it isn't and they are not!!
