Document center DC440ST error code 4011
  • laktech
    • Jun 2007
    • 17
    i have trouble with the error code 4011 of xerox DC440ST. The error occurs when power on.
    please give me a hand to solve the problem or send me a the services manual if possible.
    Thanks a lot.
  • xcopytech
    • Aug 2006
    • 1792
    DC 440ST
    There is no such fault code on Xerox DC 440ST. Check again and I will help you with that.
    xcopytech@gmail.com
    regards.
    • laktech
      • Jun 2007
      • 17
      Thank you was care this prolem.I haven't service manual for it.When power on,the desktop display "please wait system warm up" then "error code 4011 and nothing more.How to display error code exact.
      • laktech
        • Jun 2007
        • 17
        • Mr Spock
          Vulcan Inventor of Death
          • Aug 2006
          • 2064
          Actually there are a few number only codes on this model they were testing/development diag codes. They were "turned off " in the third or fourth firmware revision. You had to call engineering support for the answer.
          Otherwise this could be an n7-11 or U8-11 code (both point to the hard drive being bad ).
          • yasir
            • Mar 2007
            • 19
            dc440 error code 4o11
            this kind of faults occare due to bad sectors if possible replace the hard desk or remove these bad sectors,good luck
