Xerox 240 Fatal error
  • Zorr59
    • Aug 2025
    While running a print job, the copier just stops and says "A fatal error has occurred. Shutdown copier and restart. No code given on the copier screen. On the fiery Command Workstation screen it says the same thing with this code DFE-008. I turn both the top copier switch and the black switch on the bottom front and all comes back up. runs some more than does it again. It has also done this a few time when you first turn it on in the morning.
    Any Ideas as to what this is???
    K
  • Zorr59
    OK Figured out that it is an 042-326 error. IBT Issue. Nevermind!!!!
