I have Xerox DC 240 with strange print quality problem.
When I make copy off the glass the quality is OK with both on "Heavy cardstock or ragular 20lbs paper".
When I print out with 20lbs ragular paper the quality is still OK.
But when I print out on heavy cardstock the quality is not good the colour is weak and almost totally different. I did the auto gradaition and IIT calibration. I don't know what to do next. Any idea what I should do?
P.s I'm not so sure if I did the calibration 100 % right.
I can sent you the file if you need to see the file.
Thanks,
Thanks,
