general fax prblems
  • gregoryk
    • Aug 2025
    general fax prblems
    Hi friends i wonder.If you receive a call from a customer that tells you he has a problem with his fax.He can't sent or receive faxes.How you determine that the problem is his line connection?What steps are you fallow?And how the damn can you give them to understand that?I m getting mad when i'm in front of these situations
  • PinevskiS
    • Jul 2009
    • 283
    I never work on XEROX machine, but try to cut first and fourth wire on tel.cable.
    • ApeosMan
      • Nov 2009
      • 183
      The customer MUST test their actual fax line first. If they have another fax machine test it on the line, or get their phone company to test the fax line. Most fax issues are line related and not device related.
      If the customer insists that you come out to look into the problem, and you find it's not device related, but line related, charge them for wasting your time.
      Fax really annoys me, I wish businesses would just move away from it, but instead they are moving down the VOIP path, which opens up another can of worms with regards to faxing.
      Also make sure they have a dedicated fax line, meaning no security alarm, internet or other device sharing the same line, if they do it's asking for problems.
      • copytech200X
        • 264
        1)disconnect fax line fr machine ,all lightning protector or any alarm system and plug in normal telephone (test make incoming call to your handset)
        2)if you heard distortion noise then asks customer check her phone company
        3)internet line connected to this dedicated line then your customer must have micro filter to separate voice and data signal.
        • montana
          • Aug 2008
          • 392
          hi...print activity report or journal report to see the sent and recieved faxes status and obtain if there's any wrong in comunications ..also print the user settings report if there's something abnormal..check the line wires and make send and recieve test..i wish it help..good luck.
          • gregoryk
            thank's for the support
            • andy21557
              Help Desk Technician
              • Jul 2009
              • 62
              plug in a regular old telephone into the line see if it works .. i always used to carry one ... cheapo from the thrift store for 3 bucks sure saved me alot of headaches
