Xerox DC C240 Error
  • Valu
    Xerox DC C240 Error
    IO have a Xerox DC C240 after replacing the A1 Drum this msg appear
    "A fault has occurred, some features may be unavailable, Contact your System Adminisrator"
    Any idea how to fix this?
    Valu
  • xcopytech
    • Aug 2006
    • 1794
    first post here which fault code you have
    without that we can not help you
    • maich4s
      • Mar 2009
      • 86
      hello Did u ever get the error code?
      • Valu
        error code : 006-277 and 007-104
        • xcopytech
          • Aug 2006
          • 1794
          6-277 IIT/DADF Communication 6-277 IIT/DADF Communication
          Communication cannot be established between the IIT/IPS and the DADF Control PWB
          7-104 Tray 1 Feed Out Sensor 7-104 Tray 1 Feed Out Sensor
          Description
          The Tray 1 Feed Out Sensor does not detect paper fed from Tray 2, 3, or 4 within the specified time after the Takeaway Sensor was actuated.
          • wlloh08
            • Jun 2010
            • 15
            The error code wont get you the mesage of same feature is may unable , it could be the NVM as corrupted. Try to reset the MCU & ESS
            • copytech200X
              • 264
              do you change drum assy or just drum chip /fuse?if you change drum fuse try another drum fuse.
