Docucolor 250 finisher error code 012-335
  • savedsoul
    • Jul 2009
    • 49
    When I connect the finisher to the machine I get the error code 012-335. Anyone know what I should check please?
  • gregoryk
    012-335 RAP Booklet Sub CPU Communication Fail.
    • Check the connectors at the Finisher PWB and the Booklet PWB are connected or seated correctly
    • Check the wiring between the Finisher PWB and the Booklet PWB for damage
    • maich4s
      • Mar 2009
      • 86
      solution
      i have sent solution to you email(savedsoul),let me know if it has sorted you out!good luck
      • JeffOlimpio
        Re: Docucolor 250 finisher error code 012-335
        You could help me in this error finisher 012-335, Already re-installed the software em All_in_One C finisher and nothing! This occurred after the restart the NVM (output Finisher).
        Thank you so much!
