need instructions REP 9.3 Docucolor 240/250/260
  • copierpro
    • Apr 2007
    • 270
    If anyone has a link or document they can attach with instructions on changing the IBT belt I would appreciate it. We need to change a belt and do not have the instructions my tech won't touch it without those.
    Thanks in advance
  • Valkon
    • Oct 2008
    • 3
    Xerox DC 250
    In Russian, but with pictures
    • copierpro
      • Apr 2007
      • 270
      thanks I'll have a look.
      I just got this 250 in and the copy controller box that mounts on rear of copier is gone. I assume that would be the FieryX2 embedded? Or is that just a copy controller box like what is found on rear of a WorkCentre 7665?
      If I want to hook up an exp250 I do not need the rear box do I? I would assume I could take a crossover to the copier and scsi cable from exp250 to scsi on copier?
      Thanks for your help
      • panchito2099
        Fiery
        You are correct the missing box was the Bustled Fiery.
        You can replace that with the Fiery EXP250 you have and the cable that came with it.
        I have the image of the REP9.3 in english, please send me your email to scan and mail it to you.
        Cheers!
        • copierpro
          • Apr 2007
          • 270
          email
          thackett@copiergeeks.biz
          thanks for your help.......question: I got a crossover cable for rip to copier but what is the Xerox part number for the scsi cable from Fiery to copier? I need to order one and they know nothing at Xerox without a part number
          • jayc67
            Independent technician
            • Sep 2009
            • 100
            Hello,
            Can anybody tell me what kind of version of Acrobat pro I need with command workstation 4.6.0.34 for DC260? I have a DC3535 who work correctly with acrobat 5 but when I test to impose with the bustled fiery of the DC260 it makes an error.
            I'm sorry for my english. I hope that you understand.
            • Milo Wilson
              • 502
              I believe you will need the Impose option installed. There is a USB dongle that has to be used to enable the impose function.
