Xerox 5028 - L6 Error
  • kharding
    Hi folks,
    I was referred here because I was told you might be able to help me...
    I have an old Xerox 5028 copier that is being frustrating... It is displaying an L6 error that will not clear and will not allow the copier to operate. I know that L6 means a key counter error has occurred. The copiers used to have key counters but do not anymore.
    Is there a way to clear this error?
    Kevin
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    If memory serves there were two types of those used.
    One had a small pcb under the left front cover with dip switches and the other was a hard wired jumper in the back right corner.
    The pcb is as simple as flipping the dip switch that turns it on and off. I don't remember which one, it has been three years since I saw one. For the other it is simply reconnecting the wire.
    • Canuck
      Tech Specialist
      • 1713
      Yep...dip switch on foreign interface pcb under front upper cover(under console)
