Xerox 7228 7235 7245 scan key
+ More Options
Posts
  • artphil
    • Aug 2008
    • 155
    Hi Guys,
    I need the key for enableling the Scan to file option and the one for the Scan to e-mail.
    I need to use it on a machine wich has already all the neccesary hardware but has been ClearAllFlagged.
    Please post it for me or send it to my e-mail address artphil@gmail.com
    Many thanks!
    Artphil
  • johnner66
    • Mar 2009
    • 265
    first find one m/c with all fuction copy the data and put the one you need the all fuction
    • artphil
      • Aug 2008
      • 155
      Hi Johnner,
      I don't really understand what you try to explain.
      Where can i find this data?
      I need an software option key in the menu.
      Do you have another solution?
      Kind regards,
      Artphil
      • darkfocus
        codes
        Check your email account .....
        Originally posted by artphil
        Hi Guys,
        Many thanks!
        Artphil
        • pisboi
          Re: Xerox 7228 7235 7245 scan key
          Hi
          I am interested in the same e-mail.
          Could you send it to pisboi(at)hotmail.com ?
          • axel
            • Sep 2011
            • 36
            THE SCAN KIT KEY IS : N8TPGtn9yYV3
            If you have network scanning code you also have Email -->
            Go to "Key Button" (on your display in the right upper corner) fill in 11111
            Then go to system settings --> then Common Settings --> Screen / Button Settings
            then go to 5. All services --> select a free space --> push Email.and save and resart the machine
            By start up you will see that email is active.
