Xerox M24 Color Copier
  • higherlevel
    • Aug 2006
    • 30
    Any one had a Wrinkling problem with a M24 Color Copier....Changed a new fuser, still has wrinkling, SOMETIMES....
    Letter or Legal...does not matter....Duplex seemd to be the most problem..but has happened on single side also...
  • techguy75
    what lb paper are you using and is the machine set for the right kind of paper also is it in a damp or humid place? alot of times moisture alone causes that problem but can be crappy paper also.
    • higherlevel
      • Aug 2006
      • 30
      M24
      Thanks for the Response....
      20lb is being used for the 11 x 17 paper....
      Paper is fine...
      This problem has occured at 2 different customers locations with this machine...We ended up changing the fuser, (EVEN THOUGH THE FUSER LOOKS GOOD) at both locations and it has fixed the problem...
