One of my techs is working on this MFP and we are both perplexed and don't know what to do. The MFP says that it is ready to copy but if you try to copy, print, or fax nothing will happen. The print queue shows all the print jobs that need to be printed but will not print out. When you try to fax out it accepts the fax number but then does nothing. Tried to take off fax option to see if it would make any difference but no change. The customer said that the MFP will reboot by itself often. Tried to look up any error codes but machine does not show any?
Xerox DC-432 says ready to copy but will not copy or print or fax
