WorkCentre 7132 software option code SCAN to Email
  • airborn9
    I have bought a WC 7132 without the software option code SCAN to email, but I need this option to do my work. Xerox told me that this option isn`t available anymore, because this machine exist no longer as new machine . Can anybody help me to fix this problem and send me the software option code?
    Kindly regards,
    Edit: Thanks a lot for your help! I found already a solution.
    Pls close thread.
  • xeroxsharp
    • Nov 2008
    • 270
    Did you try to enable scan to e-mail: IE,IP ADDRESS,PROPERTIES,CONNECTIVITY,PORT SETTINGS,SEND E-MAIL- MUST BE ENABLE
    BR
    • artphil
      • Aug 2008
      • 155
      Hi Airborn,
      Please share the info how you solved this problem, maybe someone else has the problem too and then he or she can find the solution too.
      Thanks,
      Artphil
      • dinkyoaf
        • Sep 2010
        • 63
        Pls close thread.
        Solution!?!?!?!?
        • airborn9
          Hello!
          I have bought the software option code from a very small austrian dealer.
          It was not cheap but it helps me to do my work.
          airborn9
          • darigh
            Re: WorkCentre 7132 software option code SCAN to Email
            Kindly regards,
            Pls close thread.
            Hello, I have the same problem like you...
            Can you send me the solution...
            my email: darigh(at)gmail.com
            Thank you very much
            • darigh
              • airborn9
                Thank you very much
