Xerox 3535 print problem
  • emcreklam
    • Sep 2008
    • 9
    Hello
    My first post
    I bought a used Xerox 3535
    First printed pages were good, but after a few prints appeared blue background and now does not recognize magenta toner, although the full.
    View images
    Thank you in advance for your help
  • xcopytech
    • Aug 2006
    • 1792
    for cyan it is look like drum is bad, replace drum and see will you have better print.
    about magenta you will need to check drum and developer bias contact.
    also will be good to find some local tech who have xerox pws.
    • Orlando
      Re: Xerox 3535 print problem
      Did you have any luck with the background image problem as I have just having same problem
      • Tinochka
        • Jul 2012
        • 127
        Take a look at magenta developer housing. It looks like there is lack of developer material.
        Probably you need to replace developer material in magenta developer housing.
        And try to clean glass of laser window for cyan clolr
        good luck!
        • Orlando
          Hi I have a problem with my Xerox 3535 copier when copying from the glass its fine, however printing from the mac or pc the cyan prints negative and out of register can anyone help?
          • adriansto
            • 2383
            Post here a sample.
            If copy is good then the problem is probably on your rip controller.
            Try to reseat the two DDI cable who connect the machine with the rear side controller and try to reload controller software.
