DC260 Error code 042-326
  • pal.xerox
    HI ALL,
    Can any one help me how to reset 042-326 error code in DC260 machine is with external rip docusp 5.1
    pal.xerox@gmail.com
  • xcopytech
    • Aug 2006
    • 1794
    clean ibt belt and sensor in belt assy and then in nvm 741-105 to 0 and perform registration adjustment in diagnostic
    • Goshe
      • Jul 2009
      • 118
      Check that the reflection mark on the IBT belt is in position,check the IBT belt home sensor (I think it was 042-200). Set 741-105 to 0
      or maybe you should clean the Belt and reflection mark.
      • maich4s
        • Mar 2009
        • 86
        pal.xerox,,do you know how to get to diagnostic?coz thats the only way to get the machine up and running and thats also where you change your NVM.
        copytech,,why do you have to do reistartion adjustments after you perform the simple NMV change??i would really like to know.
        • pal.xerox
          well thanx to all for this help.
          i know how to enter diagnostic through control panel hold 0 key and start 6789. .....
          for registration when we remove the belt its registration can be out for this porpuse we need to run belt edge learn setup. yes u right if problem can b resolved to change the nvm velue then no need to run any setup.so first we need to check print before start and adjustment.
          • maich4s
            • Mar 2009
            • 86
            You are most welcome pal,you can ask anything concerning xerox dc12,250,wc7665,7655
