Xerox DocuCentre-II 2055 error 016-315
  • Clif
    • Jan 2007
    • 49
    [Error Code] Xerox DocuCentre-II 2055 error 016-315
    Hello
    I have a DocuCentre-II 2055 in the field with error 016-315 on the display. I have replaced the IOS PWB(scan PCB) but this has not cleared this error. I do not have the service manual so cannot look up this code & solution. Any help would be appreciated.
    Regards,
    Clif
  • johnner66
    • Mar 2009
    • 265
    the code is iit interface fail try the ess n iit pwb if still cant my advice is clear the nvm for all
    • Clif
      • Jan 2007
      • 49
      Hello Jonner66
      I cannot identify the parts you suggested above. Do you have the parts diagram you could post or perhaps part numbers or even a clearer description of the location of the PWBs?
      Regards,
      Clif
      • Clif
        • Jan 2007
        • 49
        Hi guys
        I have replaced the iis & ess PWBs & now have a 124-315 error. I will try initializing the NV ram next. Any other suggestions?
        Regards, Clif
