Dcc 400 116-321
  • ck1
    • 485
    [Error Code] Dcc 400 116-321
    May i know how to settle this code , machine can't copying ... thanks
  • wlloh08
    • Jun 2010
    • 15
    pls try to reload a firmware, it may help you
    • widewings
      • 16
      it needs a new hard drive. it will boot up if you remove the hard drive. the only problem is you can't scan and send email.
      • copytech200X
        • 264
        remove hard disk then power on machine..if ok hard disk needs to replace.if NG then reload firmware or removed ur ess board to another working machine and power on ..it should works
        • ck1
          • 485
          can i put dcc320 ( problem ) to Dcc400 to try ? thanks
          • copytech200X
            • 264
            yes ...ess board DCC320 and DCC400 are same except DCC240.
