DocumentCentre 432DC
  • bojans
    • 1313
    HI
    I have strange problem with this one.
    When i turn on machine and it gets in ready mode there is no copy counter & serial no, and can't copy when press Start button. When tried to enter diag mode it says there is some job in queue, and should confirm that I agree with deleting that nonexistent job, but never enter into diagnostic....
    But when I turn on machine without copy cartridge or with opened duplex cover it comes in ready mode and when press Start button it works & i can enter diagnostic without problem.
    I have already replaced UI and IIT/IPS PWB located on scanner assy..
    Could it be problem with wiring between this two boards or what????
  • suckis
    • Dec 2006
    • 165
    Did you try to replace the CRU?
    ! RTFM !
    My site: http://www.e-club.gr/
    • bojans
      • 1313
      No...
      Are you familiar with this problem? Have you seen this was happening with bad cartridges. I believe this is not original cartridge,
      but i've seen bunch of those working without problem!
      • Enzo
        • Jul 2009
        • 413
        I have a xerox DC230 and sometimes gets to me this trick. Resolve it by opened the duplex cover and it works. I use american cartridges with italian chips.
        • bojans
          • 1313
          Thanks for replying...
          Forgot to post back.
          Problem was solved by replacing battery, which i thought first... But unfortunately I replaced UI board with bad one and i didn't measure voltage on battery. There were 0.3V. Now it works fine.
          By
          • nmc172653
            • Jun 2010
            • 7
            Originally posted by bojans
            HI
            Did you try to reload ESS software?
            • bojans
              • 1313
              As I posted before, problem was solved by replacing battery on UI board/
              BR
              • Enzo
                • Jul 2009
                • 413
                I will try to reload the software but do not think I can!
                • bojans
                  • 1313
