Xerox 510 wide format only as printer! is a problem!!
  • anmi89
    The machine does not give me option to photocopy only as printer. The panel comes
    March 22, 2004 release day
    SE: OK
    and does not leave the panel ready (does not load the system as it should be). Please I need your help, URGENT, to solve this problem, this happened from one day to another, and not working!... . I would appreciate suggestions to solve it.
    Andrea
  • SEnder
    • Jun 2008
    • 36
    Enter ip of controler in IE. Check if "DDS enable" is checked.... also chk cables.
