Error fiery x12 dc12!
  • Enzo
    • Jul 2009
    • 407
    I have a problem with the fiery x12 xerox dc12. when I turn on the Fiery shows "loading" and stops loading. Last month I pressed the fourth button and I pressed "install software". I put the installation CD and everything is back to work today but the error is back to show up and just press "Install Software" screen remains blank! I changed the player and not go! I changed HD and wrong! What can I do? I'm desperate!
  • johnner66
    • Mar 2009
    • 265
    what i do is get a working h/d write it to another working hd and try it work fine good luck
    • davidj7
      • 1107
      if the error is comming often your hard disk is need of replacement. Put a new hard disk and then install the software.
      a machine is only as good as your tech : source:screwtape ; the scary one
      • Enzo
        • Jul 2009
        • 407
        the error commings often. I changed my hd and now it works!
        • maich4s
          • Mar 2009
          • 86
          hello,could you help me out with the x12 installations cdz,i dont mind having copies.maich4s@yahoo.com
          • RRodgers
            • Jun 2009
            • 1947
            Yep the HDD is going out. Time to replace it.
