phaser 7400
  • tech9
    • 216
    phaser 7400
    Hi there got a tech whos go into diagnostics and says it is now asking for a password? any ideas ?
  • Capstone
    • 35
    Interesting, I never knew the 7400 to have a password lock out before and I have had mine for 4 years now?
    If the guy is a tech, and he works on the 7400 a bit, he should know the default password I would think?
    • blazebusiness
      SanDiegoCopierRepair.com
      • 1250
      try 0000 - works on the Oki 9600c - hope this helps you
      • blazebusiness
        • 1250
        Basically same machine my friend. The xerox Phaser 7400 is 100% manufactured by Okidata You may be correct though - xerox may have different password. Xerox had oki change certain design items ie: display , toner ctg chips image unit tabs etc.. By the way - where's the Canon stuff on your site? Send me a PM if you like...I need to purchase some stuff-thanks
