Xerox 7245 with error code 124-315
  • annik2009
    • Jul 2025
    Hi everyone,
    I have a Xerox 7235 here with error code 124-315.
    Hope you can help me out.
    Kind regards,
    annik
  • Milo Wilson
    • 502
    Purpose
    The serial no., product no., and billing count are stored at three locations; the MCU NVM PWB (IOT), the SEEP ROM (SYS1) on the Backplane (BP) PWB, and the ESS NVM PWB (SYS2). This procedure allows the data in all three locations to be synchronized in case of replacement of one of the PWBs, or due to data corruption associated with one of the following faults:
    • 124-324 (3 Billing Counter Mismatch)
      124-325 (1 Billing Counter Mismatch; Unable to recover Billing Counter during recovery)
      124-312 (Product No. Mismatch)
      124-313 (Serial No. Mismatch)
      124-310 (Product No. Failure: Not initialized)
    • 124-311 (Serial No. Failure: Not initialized)
    Procedure
    1. Enter UI Diagnostic mode ( Accessing UI Diagnostics).
      Select Adjustment/Others.
      Select Machine ID/Billing Data Settings.
      Select a PWB with the correct data.
      Select Start.
    2. Enter the correct serial number in the Serial Number screen and then select Confirm.
    • annik2009
      thank you very much for your help : ) ,best regards annik
      • Nildera
        • Nov 2014
        • 13
        Re: Xerox 7245 with error code 124-315
        Hello I have a xerox 7242
        and the display showing 124-315 error, I tried sinchronized IOT SYS1 and SYS2 But the printer not recognized the sys2, (only stars)
        Could you please tell me what I need to do to the printer recognize it please????
        thanks
        Nildo
