xerox 6030 wf
  • ESA
    • May 2025
    [Error Code] xerox 6030 wf
    I have a client that picked up a xerox 6030 wf. I was told it was running ok but when I turn it on I get a 03-302 error. This error according to the manual is one or two defective power boards. I have seen on another post where someone changed them and the code never cleared. Has anyone worked on this unit and secondly have any eperience with this code? Machine doesn't get pass error code. I have clean the code log in memory.
  • xcopytech
    • Aug 2006
    • 1783
    First, check HDD in ESS (controller), Maybe you will need disk recovery cd to restore HDD.
    If still machine declare such code, then check IOT IF PWB or MCU PWB.
    • ESA
      My gut was thinking HD but I don't have a recovery CD and it seems that it is not a popular product. I haven't checked the MCU PWB yet. I'll give it a go.
      • ESA
        I tried to PM you but you box is full. Just an FYI. Thanks for the input. If you have a line on a recovery CD and can tell me where I can get it. I have no tech contacts in my area that work with this unit.
        • SEnder
          • Jun 2008
          • 36
          Short
          Try first recovery Cd. If not, replace 160K88462 IOT IF PWB.
          • ESA
            I am waiting for a supplier to see if they can track down the IOT power board. Hopefully one day I'll get the good news.
            • ESA
              Does anyone have a source for the IOT IF Pwr board? Maybe an independent dealer or vendor.
