Xerox phaser 7400 u19 code
  • Bluezman
    • Mar 2009
    • 33
    [Error Code] Xerox phaser 7400 u19 code
    Hi All I have this Xerox 7400 that has a U18 yellow LCD I have replace the led unit however the code keeps coming back
    BM
  • landspeeder
    • Feb 2010
    • 355
    [C][M][Y][K] LED Failure
    Applicable Status Codes:
    Code U18:
    Yellow LED Failure
    Code U19:
    Magenta LED Failure
    Code U20:
    Cyan LED Failure
    Code U21:
    Black LED Failure
    Initial Actions:
    Cycle the printer's power.
    If the problem persists follow the procedure below.
    Troubleshooting Reference Table
    Applicable Parts Wiring and Plug/Jack References
    LED Head, PL1.1.2
    LEDPWR harness, PL12.1.20
    LED Relay Board, PL12.1.34
    YK LEDDATA harness, PL12.1.21
    CM LEDDATA harness, PL12.1.22
    Print Engine Map 1 (page 10-4)
    Print Engine Map 3 (page 10-6)
    Print Engine Map 13 (page 10-16)
    Print Engine LED Heads (page 10-37)
    Troubleshooting Procedure Table
    Step Actions and Questions Yes No
    1
    Check LED Head.
    Exchange the affected LED Head with
    another LED Head.
    Does the error move with the LED Head?
    Replace the LED
    Head.
    Go to Step 2.
    2
    Ensure the LED Head harness is properly
    connected and not damaged.
    Is the wiring harness defective?
    Reconnect or
    replace wiring
    harness.
    Go to Step 3.
    3
    Check harness continuity between the LED
    Head and the Engine Control Board.
    Is there continuity?
    Go to Step 4. Replace the data
    harness.
    4
    Head and the LED Relay Board.
    Go to Step 5. Replace the power
    harness.
    5
    Check for +5 V to the LED Relay Board.
    Disconnect the POWER connector.
    Is there +5 V between POWER-1 <=>
    ground?
    Replace the LED
    Relay Board
    (page 8-126).
    Go to Step 6.
    6
    Check for +5 V at the LVPS.
    Disconnect CN1 from the LVPS.
    Is there +5 V between CN1-1 and CN1-2?
    Replace the Engine
    Control Board
    (page 8-112).
    Replace the LVPS
    (page 8-121).
    You never realize how cheap a professional is until after you let an amateur do it.... and
    if this was an easy thing to do then everybody would be doing it! But it isn't and they are not!!
