Xerox WC 7132 with error code 089-311
+ More Options
Posts
  • butch
    #16
    Re: Xerox WC 7132 with error code 089-311
    Originally posted by delosangeles
    Hello everyone
    I have a client with a Xerox WorkCentre 7132 full color copier that displays on power up error code 089-311 I am Ricoh tech so the newer Xerox models are bit of a challenge for us. I would be grateful for any help with a discription of the code and if there is a way to clear it. I don't know how to enter the service modes so I could use your help or if a part would need to be replaced.
    Thanks everyone
    i have had that problem many times.the patch (silver) on the IBT belt is scratched or damaged. most of the time replacing the IBT assy is the only way to resolve the problem. try cleaning the patch and the sensor and if it doesnt work then the belt will have to be changed good luck
    • Scarecrow
      • Oct 2010
      • 234
      #17
      You might check our Xerox parts suppliers for the the "shiny repair tape" --
      • butch
        #18
        i tried the tape and most of the time it did not solve the problem.ifthe patch is damaged the belt has a lot of copies on it. also the drive rolls are worn or dirty. instead of going back two or three times i replaced the belt or the entire assy. xerox has lowered the price on the assy recently to about 300 dollars. changing the assy will fix the problem
        • nedcap
          #19
          halo
          hoe haal je de ibt belt eruit en waar zit de sensor
          • livewire
            • Sep 2011
            • 608
            #20
            translate.google.com
            how do you get the ibt belt out and where is the sensor?
            Hi nedcap,
            Use the REP 4.2.2 IBT Module from EDOC.
