same as a sharp sf2014....how do you get into service mode so I can reset the counter...
thanks
d
You never realize how cheap a professional is until after you let an amateur do it.... and
if this was an easy thing to do then everybody would be doing it! But it isn't and they are not!!
Diagnostics:
To enter diagnostics: Turn on the copier while holding the โ0โ button... all display panel indicators will light.
To enter a code: Enter the first part of the code followed by the 'Print' button, then the second part of the code followed by the 'Print' button again.
what is the code for clearing the service indicator
