xerox 7328 4-361 code
  • dan jam
    • Jun 2025
    [Error Code] xerox 7328 4-361 code
    Can anyone tell me what this code is, I have no access to manuals. Any help would be greatly appreciated
  • TzALbg
    • Dec 2007
    • 111
    4-361 Check the Y-M-C CRU's
    4-363 Check the K CRU.
    Turn the gear in a clockwise direction as viewed from the gear (rear) side of the CRU.
    If the gear binds or is hard to turn replace the CRU.
    Use one of the other CRU's to compare the force needed to turn the gear.
    Also check the IBT belt for a label or the residual glue from the back of a label.
    • dan jam
      Thank you for you"re reply, thats a great help.
