wcp 65 manual
  • vmx12
    • Sep 2007
    • 55
    wcp 65 manual
    Does anyone have any documentation on this machine. Manuals justmanuals doesn't seem to have anything. Having a few issues with one I told a customer I'd look at.
  • bojans
    • 1313
    If you mean wcp 65 Lakes family, I have Edoc, could upload for you. Do you have PWS?
    • vmx12
      • Sep 2007
      • 55
      Thanks but no I don't.
      • vmx12
        • Sep 2007
        • 55
        Does a 5665 come close?
        • bojans
          • 1313
          That's the only version I have.
          What's your problem? Maybe someone could help if you post that issues.
          • vmx12
            • Sep 2007
            • 55
            Yeah I getting turn power on and off repeatedly
            with codes:
            9.370.00
            14.300.00
            7.202.03
            12.232.00
            Any help would be much appreciated.
            • bojans
              • 1313
              I can list error codes from documentation:
              Fault Code, 09-370, indicates that the Transfer HVPS fuse is open or that the power supply is on in standby. The Transfer Fault Monitor signal is High when the Transfer Enable should be Low.
              14-300
              The control system did not detect a signal at the AGC patch, which indicates the Illumination Lamp is not lit or there is a failure in the video path. Scanning is disabled with this fault.
              Probably video cable.
              07-202
              The Stack Height Sensor senses the Paper Tray is not in the feed position after the Tray Elevator Motor has been on for 7 seconds.
              Ensure the Stack Height Sensor actuator flag on the rear of the paper tray is seated correctly and moves freely without binding. If the actuator is broken or missing, replace the Paper Tray
              • vmx12
                • Sep 2007
                • 55
                Thanks for your help. I'll start with the LVPS.
                • Silvio Ribeiro
                  • May 2008
                  • 34
                  This site has PWS is just download and install, this file already has the documentation of some machines colored Xerox PWS Collection 1 (download torrent) - TPB
                  • bojans
                    • 1313
                    It doesn't contain diag for wcp 65
                    • Silvio Ribeiro
                      • May 2008
                      • 34
                      This link has only a few colored machines, I have the EDOC DP65 and D265 if you want to pass an email to my private email.
                      Now I do not know if this works with the diagnosis PWS documentation works.
                      • Silvio Ribeiro
                        • May 2008
                        • 34
                        • bojans
                          • 1313
                          I have it all.
