XEROX WC 7132 error-"116-380 PLEASE REBOOT"
  • screwdriver08
    • Jul 2010
    • 160
    [Error Code] XEROX WC 7132 error-"116-380 PLEASE REBOOT"
    I had this xerox workcentre with an error code 092-310, which told me to check three parts on the copier, so i just went ahead and ordered the three parts that the manual said might be causing the problem. After changing the parts and turning it on for the first time, it says 116-380 please reboot...does anyone know why that is happening and how it can be resolved without buying more parts?
  • tech9
    • 216
    Reseat your dimms on the ess pwb most probably th R1 Dimm.
    • screwdriver08
      • Jul 2010
      • 160
      How do I reset the dimms on the ess pwb. can you please tell me how to do that? I have no clue how. When I turn the copier on it only show 116-380 please reboot, and I tried to get into the UI Diagnostics and I couldn't. I checked on the Manual and it says that I need to replace the PS DIMM, but when I checked, this computer does not have that on, it also says on the manual that the PS DIMM is optional, so I guess came without one.
      • tech9
        • 216
        sorry i ment reseat dimms.
        • screwdriver08
          • Jul 2010
          • 160
          This Copier does not have the PS DIMM on the Printer PWB, It however has the PC133 SO 0DIMM on the ESS Board. So which DIMM should I reseat?
          • tech9
            • 216
            What parts did you originally change ? according to the edoc the problem is the printer pwb or ess pwb. Did you change any of these ?
            • screwdriver08
              • Jul 2010
              • 160
              I have not changed the Printer PWB or ESS pwb, I only changed the ADC sensor bar and the MCU pwb because of the first error code 092-310. Now it displays 116-380, however I took out the printer pwb and it is working, but only as a copier. so I guess I need to order another printer pwb.
