2nd btr error code, now shows grayed out copy function, need nvm reset i think before it will return copy function, no diagnostics tools to get code if that is the problem, any help is appreciated
workcentre 7345 error code 009-349
Tags: 2nd, code, connections, copy, diagnostics, error, error code 009-349, lef, reset, shows, tools, workcentre
[IMG]pws://file/xerox/edoc/wc7228-7235-7245/icons/wordproc.gif[/IMG] 009-349 1st BTR Retract
[IMG]pws://file/xerox/edoc/wc7228-7235-7245/icons/arrwup.gif[/IMG]BSD On
9.18
[IMG]pws://file/xerox/edoc/wc7228-7235-7245/icons/arrwup.gif[/IMG]Description
The 1st BTR did not reach the retract position.
[IMG]pws://file/xerox/edoc/wc7228-7235-7245/icons/arrwup.gif[/IMG]Initial Action
- <LI id=svc.imper.0000257313>Clean the 1st BTR Retract Sensor ( PL 5.4) and check for damage.
- Check the 1st BTR Worm Gear and Retract Shaft ( PL 5.4) for breakage.
[IMG]pws://file/xerox/edoc/wc7228-7235-7245/icons/arrwup.gif[/IMG]Procedure
In sequence, enter the following: Component Control [009-054] then dC330 [009-055].
The 1st BTR contacts and retracts. Yes No Unanswered
There is +24VDC from P/J539-A16 on the I/F PWB to GND. Yes No Unanswered
Go to the +24 VDC Wirenets and troubleshoot the problem.
Check the wires between P/J539 and P/J237 on the 1st BTR Retract Motor for opens, shorts, or loose connections. If the wires are OK, replace the 1st BTR Retract Motor ( PL 5.4). If the problem continues, replace the MCU PWB ( PL 13.1). If the problem continues, replace the I/F PWB ( PL 9.1).
Stack Component Control input codes [004--014] (1st BTR Retract Sensor Power) and [009-203] (1st BTR Retract Sensor). Then, in sequence, enter the following: Component Control [009-054] then dC330 [009-055].
The 1st BTR Retract Sensor changes state. Yes No Unanswered
Check the circuit of the 1st BTR Retract Sensor ( PL 5.4).
Replace the MCU PWB ( PL 13.1). -
drum assy does not rise properly (in the left side). Verify left side for misaligned (rising assy with 2nd BTR)."Opportunity is missed by most people because it is dressed in overalls and looks like work. "Comment
