Resetting 077-909
Re: Resetting 077-909
please follow the nvm list with machine .
enter all the nvm chain link with the default values listed in the list .
to enter the values , you need to login into diagnostics mode of the machine ,
press and hold zero button for 10 seconds and press start button on the machines UI .
enter password 6789
scroll to tools > maitainance and diagnostics > nvm read write> enter the chain link .
especially the ohp sensor nvm value77-909 and_or 24-934.pdf xerox 550.pdfComment
well after reading all an previous post I recommend you take out the whole drawer out and check the drawer and frame rear contacts , may you have an open circuit by damage and when you close the drawer do not make a good one , in my time working with those family found even pieces of paper breaking up the circuit ,also check if one of them broken these new family some are recycle from the previous ones.
Hope it's help
Wiwa 72
Gonzos build v 1.0Comment
