Xerox M35 problems
  • savi0r
    • Sep 2010
    • 363
    Xerox M35 problems
    Hi. I have a problem with this machine. Let's say it enters power save mode. When i try to make a copy, when is exiting power save mode, it says " output communications fault". I believe it is a problem from the finisher. Anyway, i want to know how to disable the standby function ( so the copier doesn't enter power save mode ever again). Also, it says all the time that tray 2 is empty, although i have paper in it. I believe to be the paper sensor, but i want to know exactly where to locate it. Please help. Any suggestions are welcome. Btw, if anyone can share a service manual for this machine, i would be really gratefull. Thanks
  • adriansto
    • 2375
    Did you have a PWS ?
    • savi0r
      • Sep 2010
      • 363
      What's a pws?
      • JustManuals
        • Jan 2006
        • 9838
        Just Manuals | The Internet's largest selection of manuals | Instant Downloads
        Paul@justmanuals.com
        • tech9
          • 216
          I think i got this one ! This machine is a M35 so does not have a network controller but has a finisher LCSS. If you look at the rear of the machine where the finisher power cable plugs into the machine it should be pugged into the black socket not the grey/cream/or white socket this socket is for the controller.
          I have had this problem many times if you look in your fault history you will see 03360 faults.
          • savi0r
            • Sep 2010
            • 363
            Thanks for the answers. How about that other problem. It says tray 2 empty but i have paper in it. Is the paper sensor causing this problem? Can cleaning it solve it? Some steps for solving this problem would also be usefull.
            • tech9
              • 216
              remove tray 1 and open and close tray 2, make sure the tray feed assembly fully lowers. If not replace with a new feed assembly. you remove the feed assembly from the rear.
              • amadeusmbi
                • 51
                replace tray feed assy or try to reseat correctly (verify 3 supports that sustain feed assy).
                "Opportunity is missed by most people because it is dressed in overalls and looks like work. "
