DC 260
  • CT Copier Repair
    • Mar 2010
    • 304
    DC 260
    Error 042-327
    I reset NVM 741-105 to 0
    have cleaned the sensor and the patch
    IBT assembly was dropped but I cannot find any damage sensor moves smoothly looks good
    belt is showing some curling at edges normal type wear
    cleaned entire unit
    cannot run edge learn it errors out before it will run
    or runs with errors
    is 741-105 the NVM chain to be reset
    what am i missing guys
    Brian
    Oh I did get a 042-326 before but it cleared itself
    machine was moved by a customer and I get to fix it oh happy happy joy
  • ktxerox
    • Mar 2009
    • 229
    check the silver patch on ibt might be it is damadge or check belt if it has curve then it will not toch allignment sensor lever and code will appear. you can also check sensor in diagostic.
    • CT Copier Repair
      • Mar 2010
      • 304
      IU was thinking about the curl
      so the sensor has to touch the patch and the belt has to be over the sensor? Just trying to understand these monsters better
      Brian
