Xerox phaser 8560
  • screwdriver08
    • Jul 2010
    • 160
    Xerox phaser 8560
    Error: Scanner disconnected
    keeps displaying scanner disconnected.
  • JustManuals
    • Jan 2006
    • 9838
    Just Manuals | The Internet's largest selection of manuals | Instant Downloads
    Paul@justmanuals.com
    • TEKK09
      • 142
      Re: Xerox phaser 8560
      I have the same problem. Have you found out anything?
      • screwdriver08
        • Jul 2010
        • 160
        No I have not, sorry. But will let you know if I do.
        • adriansto
          • 2384
          Do you read this:
          http://www.copytechnet.com/forums/xe...connected.html
          • mjtorres
            Scanner harness wires are so tight and maybe has broken... The only way i know is replace the whole scanner...so expensive
            • screwdriver08
              • Jul 2010
              • 160
              Paul,
              I bought a Firmware from you for a CS-1820
              I checked the service manual and gave a list of the files and folders that I should put on the Compact Card. You have every one of the files except for the folders. The two folders are
              NANDinstall and NORinstall
              do you have that?
              cause it said on the service manual that it would not work with out all of those files and folders.
              • landspeeder
                • Feb 2010
                • 355
                The only way to fix it is too replace the scanner assembly ....its a internal board problem that is not parted out.....i have changed lots some more than once!
                You never realize how cheap a professional is until after you let an amateur do it.... and
                if this was an easy thing to do then everybody would be doing it! But it isn't and they are not!!
                • TEKK09
                  • 142
                  Thanks a lot for the response. Sounds like you know the problem well. That's what I was looking for.
                  • CanonSco
                    Man About Town
                    • Jul 2010
                    • 368
                    Had one last week for same.
                    Had to replace the scanner assembly in the end.
                    Yes, I am a nerd.
                    Gaming PC - check. Raspberry Pi - Check. Custom ROM on phone - check. Thick glasses - check.
