Docucolor 12 error code 10-370
  • ygeezzy
    • Aug 2009
    • 33
    [Error Code] Docucolor 12 error code 10-370
    Docucolor 12 error code 10-370 - the pressure roll did not reach the ready temperature within 8 minutes after power on...... How do i fixs this??????
  • JustManuals
    • Jan 2006
    • 9838
    Just Manuals | The Internet's largest selection of manuals | Instant Downloads
    Paul@justmanuals.com
    • xcopytech
      • Aug 2006
      • 1792
      check pressure roll lamp, thermistors.
      • alex4alltimes
        • Feb 2010
        • 68
        Check the Fuser Unit!
        Hi.... first check if the Pressure Roll ctrl thermistor is worn out or if the pressure roll itself is worn out where the thermistor makes contact. if both are ok, check the wirenets to the iot and hvps. there may an open connection, or wires may be damaged. if all else fails, change the IOT Driver board. Hope it works....
