docuolor 242, connection troubles
  • dakkafex
    • Jun 2025
    Hello,
    i am encountering some problemes with my machine, it wont connect to the computers or to the netwerk anymore, now someone sugested changing the machines ip, but i cant for the life of me find where i can change it, i dont have allot of knowledge of printer, and google didnt realy got me a result i can work with.
    so if anyone is able to help, i would be greatfull
  • adriansto
    • 2383
    Print a configuration report from machine and post it here.
    • dakkafex
      ok..how do i do that?
      • adriansto
        • 2383
        DocuColor 242/252/260 with built-in Fiery controller Support
        Type configuration report in the SEARCH box or read support page for how to configure your machine.
        • dakkafex
          Press the [Machine Status] button on the Control Panel.
          Select the [Billing Meter / Print Reports] tab on the Touch Screen.
          Select the [Print Report / List] button.
          Select the [Network Controller Jobs Report] button. The Network Controller Jobs Report button will be displayed.
          Select the [System Settings List] button.
          Press the [Start] button on the Control Panel. The System Settings (Configuration) Report will print.
          Select the [Close] button on the Touch Screen three times to e
          but at step 4 it tells me to press a button that isnt there, it only has jobs
          • adriansto
            • 2383
            What button is not there ?
            • Milo Wilson
              • 499
              Sounds like corrupted hard drive for network controller, That's probably why the network tab is not coming up ready. I would reload the ess software.
              • dakkafex
                hehe, ok and how do i reload that?(100% total noob on xerox machines)
                • Milo Wilson
                  • 499
                  You need a pws laptop and the ess firmware
                  • dakkafex
                    pws?
                    • adriansto
                      • 2383
                      The easy way is to call a xerox tech.
                      Another way is someone to provide you a usb flash drive with sistem software and instructions about use it.
                      • dakkafex
                        and could someone help me with those instructions?
                        • adriansto
                          • 2383
                          A email of you ?
                          • dakkafex
                            kazrhak@hotmail.com
                            • dakkafex
                              i have looked around and it seems i am not missing any buttons on the screen, im using a dc242, and i think i just need to find the IP somewhere
